Are you changing the pump? If your pump is noisy and the power steering goes in and out, check the screen in the bottom of the reservoir. They can clog up and act like the pump is bad. If it is clogged, remove the screen and add an inline filter. I don't know if you even have a problem but I thought I would throw this up here in case you do.
