power steering not working when idling
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
So my power steering does not work when i idle but works when i give it gas. and yes there is oil in the system. Any help would be appreciated
metaphysico
Mad Scientist
Jan 2, 2008
428
Gainesville, Georgia
The idle up just gives some extra air past the throttle plate giving you increased idle, so that should not affect it really, it just keeps it from bogging when turning at idle. Sounds like. bad pump not getting enough pressure out.
metaphysico
Mad Scientist
Jan 2, 2008
428
^ Didnt think of that yea check that for dirt, bebris, sludge. All the valve does is when you are under load from turning it will let some air bypass the throttle plate increasing idle some. This will not make the power steering not work, if its not working it will just make the cars idle drop some while turning at an idle.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
^if it was the screen then he wouldn't be getting enough fluid. In my experience with that (lack of fluid), which I have run into a lot in the past, its ALWAYS made a distinct humming noise and difficult to steer at lower RPM. But since he is supposedly not hearing anything...
Won't hurt to actually check it though.... :nono:
8,873
If he has to increase pump speed, the hydraulic portion is bad. That can be the pump or the rack, but the rack is unlikely based on symptom. The pump clearance is probably bad causing weak flow at lower rpm. More speed increases flow so you get assist.
