post your setups guys...
bobpogoman
213
Quebec, Canada
hi guyes....can you all please post your setup and how much it cost you cuz i want to make another engine for my 89 turbo...im looking to find the best part at best prices...gotta get a jdm 7mgte this winter...and then aftel i gotta invest into some mods....i wanna invest 10 000$ CDN at all...with the engine and all...
the engine will cost me 1000$ i gotta pick it at toronto...
ill be using hks stopper mhg 2.0mm....i must know what it cost at all to get it machined??
not sure for now....guyes post me your setups...
1_slo_92
145
Hillsboro Ohio
Motor:
.40 Toyota pistons with Toyota rings
New Toyota main and rod bearings
New rod bushings
ARP main and rod bolts
New Toyota water pump
Newer belts
New timing belt and tension spring
New thermostat and radiator cap
New Toyota oil pump
All new seals and gaskets
New Pass. Motor mount
New power steering pump
New upper and lower radiator hoses
New oil overflow hose
4 puck clutch w/ new TOB assembly
Fidennza flywheel
Rebuilt master and slave cylinders for clutch
Relocated oil cooler
Relocated coolant overflow
Silicone vacuum lines
Head:
3 angle valve job
New Toyota valve seals and springs
2.0 Titan MHG w/ ARP bolts retourqed
NA cam shafts
New heater union and hose
EGR eliminated
A/C eliminated
NGK 1 range colder plugs and wires
Fuel:
255LPH Fuel pump
Aero Adjustable fuel pressure regulator w/gauge
FPD removal kit
Newer fuel filter
Nothing but high octane used at all times
Cleaned stock 440cc injectors
Larger front mount
Custom IC pipes. 2.5” steel lower and 2,5” aluminum upper w/ rolled ends and silicone couplers
Turbo XS RFL BOV
Apexi intake
Catch can
Electronics:
Black SAFC2
Autometer EGR,boost, and A/F gauges
Greddy TT
CD player w/ AM/FM ( cd doesn’t work though)
Pioneer speakers
Power antenna broke but in the up position
Silverstar headlights
Dual electric fans
Suspension:
Tokico Illumina 2’s all around w/ new bump stops
Eibach springs all around
Front Greddy STB
Exhaust:
Titan Motorsport Downpipe 3”
Titan 3” test pipe
Blitz 3” Nur Spec catback
Theres mine, waiting till tax season so I can get a bigger turbo, injector's and a lex afm, or maft pro. Shooting for at least 550-600 to the wheels, maybe more ya never know.
bobpogoman
213
Quebec, Canada
kk bah all little thing are good on my engine so...ill just change timing belt for a better one..and the oil pump....for other thing i think ill get .40 oversize pistons and eagle rods with rings (a kit on suprastore) and the valve kit (1mm oversize)...hks 2.0 mhg stopper...then a good ic kit (gotta find 1)
maft pro...i found a nice turbo kit for like 2500$ on suprasport...dual ceramic ball bearing...t04e 68 trim...must boost a lot :p...i already have a stage 3 clutch kit so...i also have arp head studs...
i think the turbo...piston ring and rods...valve kit will cost me like 5500$...+ machining cost i dunno....
maft pro like 700$
jdm 7mgte engine 1000$
injectors kit and 255 lph walbro (kit from suprastore) 900$ (550's will be enuff??)
New oil pump....how much $??
then ic kit...ne 1 got a good one?
ne thing missing...??? tell me ill look for them :p
Brand new GTE block
7M Niterided Lightened Crank
+40 thou JE Forged Pistons
Pauter Rods
ARP Main studs
New GTE pump
GrpA Magnesium Pan
HKS Stopper 2 mm MHG
Clevite77 Rod Bearings
ACL Main Bearings
B&M Oil cooler
B&M T STat
Moroso ACCUSUMP
Wade Cams .351"/9mm lift 280 degrees duration 226@50thou
+1mm Ferrea Valves
Ferrea Sport Compact Valve Springs
Ferrea Titanium Valve Spring Retainers
Ferrea Valve Seat Locators
Shimless buckets
Brand new ported head
AEM cam gears
ARP head studs
Gates Timing Belt
GT35/40R 700hp roller Wastegated turbo
3.0" Aluminium Hardpipes
600x300x100 air to air IC
PWR Radiator
DC Electric water pump
Stainless Ceramic coated Header
New design FFI intake manifold
GasResearch Carb
Triple Twin lever LPG Converters
3.5" Mandrel bend Dump pipe
3.5" Metal Cat
2 x 2.5" Mandrel bend Stainless pipes
4 x 2.5" Stainless Mufflers
Bosch coils x6
Wolf V500 6 channel ECU
Wolf Wideband 02
Crank Trigger Ignition
Knock Link knock sensor
2x Haltech 3 channel ignitors
55watt 5000k HID lights
Custom OSGiken Ceramic Twinplate
Tremec TKO/500 5 speed
OSGiken Steel Flywheel
4.11 Trutrac 9" Diff
Custom IJ 9" housing
Custom Axles
GroupA V8 CV joints
Custom Stub axles
Diff cooler and pump
Chassis
Mk4 TT DBA Rotors F&R
AP Racing 4 piston callipers
SS Goodridge lines
Koni Yellow Coilovers
Whiteline Swaybars
Full Poly Urethane bushes
Eibach Springs
SS Lower Control arms
bobpogoman
213
Quebec, Canada
kk but how much could cost that setup ij??
and just a question (what did STOCK engine internals can hold in psi/hp...stock crank..valve and pistons...
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
IJ. said:
Bob: I stopped counting a LONGGGGGGGGGG time ago it's become a bit of a crusade for me to finish this thing and make it reliable!
weren't you decided to go 1uz or something? im only atl iek page 534 on your buuild thread haha
turbotrev
Goin WEEEEE on my gsxr600
Aug 7, 2006
311
Clinton, MO
original block bored +20 over(pressure tested and plained)
JE pistons and rings +.20
Eagle rods
Clevite 77 main, rod, oil pump bearings, and thrust bearing
Toga HV oil pump
HKS 2.0mm hg
valve job and plained
all new gaskets
Koyo rad
Flex-a-lite dual fan kit
hard piping upper rad hose
walbro 255lph fuel pump
rc 550cc inj
fuel press. regulator
lexus v8 afm
stock ct-26
2.5" hardpiping
greddy BOV
turboxs mbc
HKS dp
custom 3in exhaust w/ ractive muffler
ACT stg.2 clutch
resurfaced flywheel
Apexi SAFC-2
Greddy full auto turbotimer
FJO wideband o2
triple a-pillar pod w/ boost, oil press, and egt
more to come and i might of fogot some stuff
the fastest import in my hometown and its not even running right now lol (gotta love the friends for scaring all the little hondas so they wont race me for $$$$$ hehehe:evil2: )
