Post Pics of MKIII's with MKIV TT Rims
Frankenstien
204
Lower Mainland, B.C.
KeithH;1256238 said:
Adjusting the stops is a pretty easy thing once you stick your head under the car and take a look. It has been a number of years since I did mine.
Note... this is also a VERY good time to replace the wheel stop caps (a small plastic cap that keeps the metal from hitting metal when turning full lock - these are very inexpensive and should still be available from your friendly parts department).
Here's what I did.
1. Jack up the front of the car - both sides.
2. Turn the wheels full lock to the right
3. Look at the right wheel and see what hits - or is close to hitting. That is your wheel stop.
4. Turn wheels straight again.
5. Use the correct wrench to back the stops out a bit.
6. Turn wheels full lock both directions and make sure they don't hit.
Once you know where the stops are you can make the adjustments without jacking up the car. This is good for those times when you need to make just a tiny adjustment more to stop the scraping.
To replace the stop cap (assuming you have the new ones ready to go).
1. While the car is jacked up locate the old stop cap - probably has a hole worn through it from years of rubbing - and pry it off.
2. Snap the new cap on
3. Have a beer.
Like I said you will figure it out pretty quickly once you stick your head under the car.
Thanks. I've had my head under my car a fair bit, guess I never noticed them. Are they on every MKIII? Mine is a TTR. I'll have my car on a hoist tomorrow night so I can adjust them then if my car has them.
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
No spacers , 245/40/17x8 front and 275/40/17x9 rear
EthanMKIII
102
Vancouver
Thats exactly how i want my car to look when im done, so sleek/sleeper and sexy. Wait nvm u have a 89+ front bumper lol
Btw ur sigs fuckin hilarious
KeithH
Portland, OR
I can't think of any reasons that only some Supras would have the stops - or that only some cars would have the stops.
They are easy to miss if you haven't been looking for them... but they should jump right out at you when you are looking for them.
5l_eater
Jan 17, 2007
258
Maryland
yea i thought it was pretty funny as well
Any body want TT wheels PM me
RiyadYar
384
NY
Supra28;1256324 said:
Those are actually mkiv n/a rims, but they look good none the less. :icon_bigg
anyone know what the biggest tire size is that will fit the n/a mkiv 16" wheels ?
