Possible to bypass the PPS solenoid?
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
I know this has been asked before but i can't find it when i search:nono: Anyway, my solenoid went out (measured 7 ohms but and when i supply voltage to it i get no click) and i was wondering if there was a way to bypass it so i can at least have some assist with steering without having to buy a whole new rack?
Thx in advance!
It doesn't "click" ever... it's not a simple on/off solenoid it drives to a position depending on speed, if you supply it with 12v for too long it will be dead for sure though.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
You could probably buy a used non-pps rack from a yard if that's an option, otherwise its gorilla mode for some time ;)
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Yeah i figured it's duty cycle controlled to give it pps. I was just trying to follow the instructions according to the TSRM http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=SR&P=94
I think i should probably check if there is any signal coming to the solenoid, i think that may be the issue considering the okay ohm reading(unless the valve is hung up on itself)
As for a used rack.. i wish i could find any junked MK3's around here:O
Thx for the advice:)
