Polyurethane subframe bushings for the MA70 Supra
ronniek
Authorized Vendor
May 2, 2005
274
auckland
guys,
here is photo of full rear subframe bushings kit.
Ronnie
ronniek
Authorized Vendor
May 2, 2005
274
auckland
I have also noticed that the inner diameter of the stock inner steel sleeves is 17mm,but the subframe bolts are 14mm diameter.
Ronnie
ronniek
Authorized Vendor
May 2, 2005
274
auckland
BTW the bushings are 90 rockwell hardness,I can go 1 step harder to 100 rockwell if anyone is interested.
Ronnie.
ronniek
Authorized Vendor
May 2, 2005
274
auckland
$220.00us,shipping is usually $50.00u.s to US.A
The 90A shore hardness(sorry not rockwell hardness) is hard as tap washer.
There is shore D hardness which is harder.70D probably as hard as golf ball and even harder suff like 80D which is hard as bone.
Ronnie
927mgtepat said:
Price????
MidShipCivic
Honda/Nissan/Mitsubishi
Sep 19, 2005
116
Orlando Florida
You wouldnt want a subframe bushing hard as hell you'd start to feel the rear end in the car and in the case of an impact with the rear wheel / diff. you might not like what happens after some nasty tears that is of the cars frame.
Anyone get the saying a part is only as strong as it's weakest joint ?
ronniek
Authorized Vendor
May 2, 2005
274
auckland
Correct.90a shore hardness is just right for bushings
Supra Sam
33
Sydney
Can someone who has installed these give a quick run down on how they feel, I'm more so concerned with the noise.
It seems the BIC aluminium ones were pretty noisy.. well according to BIC himself it amplifies any existing drive train noises. ie noisy diff
Cheers
Sam :)
ronniek
Authorized Vendor
May 2, 2005
274
auckland
I will post photos of front subframe bushings.
The poly bushings would be as noisy as Bic spacers.
I go make softer grades of the subframe bushings if requested
ronniek
Authorized Vendor
May 2, 2005
274
auckland
These bushings will fit 88 supra.
Here is photo of poly front subframe bushing with stock inner steel sleeve.A new steel sleeve is also included with the poly bushings.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i'm very happy with ronnie's product's and communication(awesome guy).the rears subframe bushing are easy to hammer out and install the new one's.i don't have any driving impression's yet,but i'm also doing alot of other suspension mod's at the same time.i don't think i could give an honest opinion on additional noise renosance.i have a pic of them un-installed and the frame with the old shit removed.
