Poly bushings in street car driven regularly?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I'm soon going to install poly bushings into my car. But I was reading on some other car forums that people have experienced binding and squeaking after 6-12 months of daily driving, even though they lubed the bushings at the time of installation. They said they had to relube them and should have added zerk fittings.
Just wondering if I should go the extra mile and install zerk fittings before the poly goes in? Anyone else have any problems after significant miles on poly bushings?
Piratetip
Far From Maddening Crowds
1,179
69
MKE, WI
Haven't had any squeaks yet on mine.
Sounds like they are half-assing the job initially.
I put zerk fittings on all my bushings, even the swaybars.
Just another step in the installation, its easy, but takes a little more time.
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
Installed poly bushings in several of my cars now,never had a squeak from any of them(cressida has quite a bit of mileage on it's poly bushings.)
If you get black ones(Energy susp.)they are graphite impregnated,which makes them self lubricating also.
SySt
Burnsville, Minnesota
I put maybe 5k miles on my poly bushings. I installed grease fittings when I installed the bushings. I did not keep up with lubing the fittings at all and after maybe 5 months of driving the front lower control arm bushing sleeves seized to the poly andthe sleeves were then rotating inside the subframe wearing the subframe away. I took the bushings apart and re-lubed them, now I make sure to lube the fittings at least once a month.
Jimi87T
1,127
4
Colorado Springs
I have poly bushings on my BMW, and they do squeak, but like Fuzz said it only happens at very slow speeds.
And I've been running them for about 3 years with no problems, daily driven.
Mine have been in the car for 4+ years now and have done many many miles, no squeaks I gave them a coat of Castrol LMM grease when I installed them as I've had Poly's in the past that drove me bugshit.
Mo87NA
1987 7M-GE & 1991 7M-GTE
8
Upstate NY
Drove me bugshit? Tha'ts a good one. I like it ;)
jugodegolf
Phoenix,AZ, United States
Squeaks can do that.:aigo:
Did you do the zerks?
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Is this the magic grease of choice then? :)
By the way, I got the Energy bushings here, and they are black. Someone mentioned that they are graphite impregnated, but I did not see that anywhere on the box. True or false?
Btw, I checked all of my current stock bushings and they are fine, and the wheel bearings and those spherical bearings are new as well(Randy replaced them 1 year ago). It just seems that my wheel offset combined with 350-400 RWTQ is too much for the stock rubber, and I end up with tons of toe upon accelerating. Probably not ideal for traction either!
I use it as assembly lube when I build an engine it's a Moly Grease with a high melting point and seems to work very well with poly, don't know about "magic" though maybe that what all the kids with the fast NA's are using for top end runs ;)
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
According to whomever I talked to at energy(few years back,can't remember the name)inquiring about using MK2 bushings in my cressida,I asked the difference between the black and red as far as stiffness.I was told that they are about the same hardness,but the black ones are graphite impregnated.
I believe it states this on their website also.
As far as the squeaking goes,I've always just used the "formula 5 prelube" that energy supplies w/the bushings.Have used red and black bushings in several cars without a single squeak.
