Piston decision.....
Ross heaviest>JE Lightest, everything else was in between, you'd have to check manufacturers sites for exact weights I didn't save the list I compiled.
Never used an Arias in a 7M before but have used them with great success in SBC's over the years and can see no reason why they can't make a good 7M piston.
If you have a solid base tune and a good fuel system I'd go for the lighter pistons, the Ross are cut from a generic blank so the crowns are very thick/heavy.
I used JE's in my last 7M build, no probs at all but my fuel system was 2x what I actually required.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
I bought the Arias pistons myself.
Haven't installed them, but the block is finished at the shop, anyway, I have to go pick it up, but waiting for bearings anyway.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,269
64
Atlanta
On a different subject, IJ, is it sensible to have my crank rebalanced?
Obviously, the factory did some balancing, but was it adequate for higher powerlevels?
Also, how does using forged rods/ pistons affect the need for balancing? My understanding is that dynamic crank balancing is performed 'bare'. Should the counterweights be lightened to account for a lighter piston/ rod combo?
An I-6 has very good inherent balance, but anytime you change anything weight wise in the reciprocating assembly it should be rebalanced, A good shop will balance the Pistons with the chosen rings pins and clips then balance each rod end to end then build a bob weight for the crank and spin it up to balance it, the Damper and Flywheel/Driveplate should be 0 balanced on their own.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
I thought bob weights were only used on V configured engines? Not that I know anything about engine balancing, but I always wondered how they compensated for a lighter piston/rod assembly when all they seem to do is match each piston to the others, and all rods to the others on each end, then the crank is balanced on its own, without any compensating for lighter piston/rod.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,269
64
Atlanta
Ah-ok, that makes perfect sense now about the bobweights representing the new piston/rod combos.
I assume that any rod/ piston combo I end up with, is going to weigh less than the oem? I assume that forged pistons will be clearly heavier than stock, but will the rods weigh less?
I have Cunningham forged rods to use in my build.
jdmfreak
PACNW
Oct 8, 2010
2,232
north clark co. WA.
Ok so i have another related question...when the scratches were honed out i was barely within spec with stock pistons ... i recently read somewhere(that i cand find now) that forged pistons have tighter clearances.... are they bigger diameter than the stock pistons or am i gonna run into issues if i stay with 20 over?
