piston and connecting rod package on ebay
my7mgte527
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
clutch
132
Bettingen, Germany
If it were me I would go with the forged because the JE Pistons dont have enough of a side skirt to keep you from hearing a knocking noise. But that is just my opinion.
my7mgte527;1781088 said:
i found a couple piston and rod packages on ebay and i wanted to kno which would b a good set up for my engine here r the links and which would u guys recomend for my build.
http://www.ebay.com/itm/JE-Pistons-...es&vxp=mtr&hash=item43a8146cfe#ht_4574wt_1037
http://www.ebay.com/itm/Eagle-FORGE...Parts_Accessories&vxp=mtr&hash=item35b6a59471
if these packages r no good please let me know and let me kno on what set i should go with and where i can get a stock crank set up for a storker package
Can't really go wrong with either package, from memory the Wiseco's give a little higher static comp ratio, in the past Eagle Rods were cheap Chinese junk but they've lifted their game and are usable and a cheap alternative to prepping stock Rods.
Quin;1781100 said:
LOL'd :D
And one based on how many correctly built 7M's with JE pistons you've done would that be?
AJ'S 88NA
2,419
Florida
I believe the Weisco's have a smaller side skirt at least compared with stock, I believe that would keep piston slap down.
Neodeuccio
Addicted to boost...
Sep 30, 2006
846
Schenectady NY
My general rule is to never buy anything that's important from Ebay, regardless of price. Unless you know the seller (IE, Titan Motorsports or similar), you really have no effective recourse if something goes wrong. I know it's a little ridiculous, but it occasionally happens that what comes in the box isn't what's supposed to come in the box. Just make sure you're covered and getting the right stuff.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Go with the Wiseco package. Never been a fan of JE's, many I've seen have had issues with hot spots.
