Pimp the CPS
drjonez
the motor city
www.4cefed.com
the flash makes it look far worse than it really is....
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
oh god, my eyes are burning from so much bling!
looks really good, ima start cleaning mine up in a little while. any tips?
drjonez
the motor city
www.4cefed.com
heh, my only suggestion is i hope your arm is up to it... ;) just do the normal for polishing Al- 400-800-1000-2000 grit wet sanding then hit it w/a polishing wheel and some some white rouge....and BLING!
Clip
Oct 16, 2005
2,738
9
Virginia
finest grit i can find at the local hardware goes to 1500, but i do have the muslin polishing wheel and the white compound. gonna work on my exhaust heat shields when my baby gets back from the body shop. is it wise/even possible to powdercoat the exhaust mani? mines rusty, looks like a giant twisted piece o' poo
drjonez
the motor city
www.4cefed.com
1500 should be fine...
i wouldn't waste your time on the ex. manifold heat shields, they're steel! they'll just rust up....
the only way to prettifiy the heat shields or the ex. manifold is via ceramic coating. powder coat will just burn off....
