Pic request: 7M Part
Tanya
1,851
Naples, FL
Need a picture of a 7MGE (or GTE if they're the same) waterpump/clutch fan pulley. Thanks!
Tanya
1,851
Naples, FL
Hullo? Hullo? I know there's someone out there that can take a pic of this for me, or at least TELL me what is different about them. I need to buy one and I have to make sure I have the correct one. HALP
Mine is on the car sorry can't really get a useful pic!
The GTE one has an Brown shaft where it bolts to the water pump and looks like it's on Steroids compared the the GE one.
cuel
1,536
Baytown, Texas
What exactly do you need a pic. of? The fan clutch, just the pulley, or both? I have them off of my other car, and can take some pics tomorrow for ya.
Tanya
1,851
Naples, FL
Just the pulley itself. Need to know if it's compatible with a 5M waterpump and fan setup.
AJ'S 88NA
2,419
Florida
Are they interchangeable?
Tanya
1,851
Naples, FL
OK, well this is a 5M waterpump pulley:
I just need to know if the 7M pulley is relatively the same (but with the 4 belt rib pattern instead of the 5M's 7 rib)
cuel
1,536
Baytown, Texas
Oh, I just realized what you want. I have a customer's mkii('85) at the shop(one of those 1/2 done, please finish this for me, motor is kind of in, harness is just laying there, nightmare inducing type projects I happily forget about). I'll see if the 7m pulley fits with the 5m w.p. and fan, and let you know.
Edit: I'll take pictures, to.
Tanya
1,851
Naples, FL
^Thanks! Looks to be the same, at least the GE anyway.
Cuel, I appreciate your help :)
I'll be looking for a 7M crank soon, but I also needed this and had to figure out what differences there were in the GE and GTE ones, and if they were/were not compatible.
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
Do you need a pulley? I'm going to my storage in the morning, I'm almost positive I have two or three. I'll send you one, just tell me where.
cuel
1,536
Baytown, Texas
No problem.
I'd help you out with a crank out of my 86.5 n/a, but its not in good shape. Knuckle head I got it from drove it with spun bearings, and trashed the journals to a point where I wouldn't risk using it.
Tanya
1,851
Naples, FL
Made the mistake of using a GTE fan on one of my earlier 5Ms one time. Waterpumps failed repeatedly after that until I put the 5M fan back on, it was strange. 1st time the WP failed, the shaft had come out and was pushing the fan closer and closer to radiator. Other times it seemed the bearings were locking up.
No more GTE fans for me, the GE stuff works just fine IMO
cuel
1,536
Baytown, Texas
