Peak warnings (exhaust,water,oil)
SupraClaou
846
4
Athens,Greece
Which do you think are the peak warnings of the:
Exhaust temps,Water temp,Oil temps...?
I say...Exhaust: 1600-1700 F
Water : 220-230 F
Oil : 250-260 F
Post your knowlegment and facts that you have seen while driving supras!
Which are the highest temps you've ever seen on your gauges?
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Water : 220-230 F
Oil : 250-260 F
My egt peaks are set at 1200F
Wayne
di_rosa
never ending project ...
Apr 2, 2005
215
toronto
i think the egt peak temps depend on your placement of your egt probe.........and damn, 1200F? where is your probe, in your cat?
SupraClaou
846
4
Athens,Greece
Yeah...1200 F (600'C) is damn to low for the highest EGT :aigo:
My sensor is located near the Y pipe on the twins.And the highest temp.
I've seen is 1330 F (700'C)...
SupraClaou
846
4
Athens,Greece
I meant that you should have seen higher water temps. than 195F...
Specially during the summer where ambient temps are quite high.
SupraClaou
846
4
Athens,Greece
IJ.;1088727 said:
Why?
My cooling system works ;)
The hottest I've seen was 200f in traffic in summer with the air con on high.
Glad to hear that :sarcasm:
Can you describe what kind of upgrade have you done to your cooling
system?
PWR Rad
DC EWP 110 electric pump
New genuine Toyota pump
New GTE Fan clutch
10 blade GTE fan
1 x Toyota shroud fan
88c Toyota T Stat
Toyota Red coolant
MoTeC runs the pump and fan.
Yep but an engine is an engine is an engine ;)
3.0L will generate xxx heat at xxx power output.
The frontal area of the Mk3 is more of a factor in the cooling than which engine is in there be it 7M or 2J.
Claou I think runs the 2J O2W oil cooler setup so that alone would be raising his base temps if the rest of the cooling system is marginal.
Andre
115
Netherlands
hmmmmmm
F means fahrenheit right?
I have seen 900 Degrees celius on my EGT gauge
En thats About 1650F
Pls somebody correct me iff i wrong
Are those numbers to high ?????????????????????? critical
