Overkill brakes?
GotBoost?
I do
Nov 25, 2005
318
By My Computer
It's for going fast backwards! LOL. Seriously, I didnt see "rear" anywhere in the page. But $2600 seem excessive. ARZ's kit seems a lot more practical and cost effective.
rodel
SoCal
May 19, 2005
2,266
SoCal
You'll endo on those 8 pistons.
charlesshen
256
orlando
wow those things are amazing , and at same time thats a whole lot of brake
:a whole lot of brake = $1,800 not to bad
: knowing you can give your mother in law whiplash by just hitting the brakes = priceless lol
Sawbladz
1,727
Oshawa, ON, CA
The number of pistons isn't the deciding factor in the performance of a brake caliper. A caliper with fewer pistons can function more effectively if sized and designed correctly.
Zach
ECUMaster USA
Apr 6, 2005
375
TX
EvoLuTioN said:
lol like hell u need 8 pistons for the rear
Those most definitely aren't rear brakes, it's a kit for the front.
IJ, play nice :) I wonder how much piston area there is on those calipers. There's at least a whole bunch more seals that can give out :p
bowsercake
828
Irvine, Ca
IJ. said:
Yeah cos more pistons are better........ :nono:
That 8 piston caliper has less surface area than most 4 piston calipers. It's like buying a digital camera, 8 megapixel doesn't tell you much over a 6MP unless you know other specs.
The idea with multi piston callipers is to get even pressure across the entire pad face, this is a great idea as long as the rest of the system is designed to match ie: Master size and pedal leverage as well as front/rear balance.
It's NOT a case of more = better and brakes are one area that needs some expertise/knowledge and not just bolting on the blingiest parts you can find.. :nono:
