Options to route wideband harness into cockpit?
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
For everyone who has a wideband o2 installed, where did you pass the harness through the firewall?
The gromet on the driver side by the brake master cylinder is already maxed out with other harnesses/wires...so this one is out of the question.
Where else can I route the o2 harness?
I have the NGK Powerdex Wideband.
Thanks
gaboonviper85
3,236
Northeast Philly
How about where your wireharness is on the passenger side....I mean that's what makes sense to me considering it's right there at the exhaust...
I put mine up through a hole in the floor on the passenger side, the connector for the sensor (sensor to wideband wires) had a place to clip into a hole, so I drilled a hole in my frame and put that there, it is very clean, I can post pics tommorow
Txsupra
Professional Driver
Aug 23, 2008
239
Texas
gaboonviper85;1400692 said:
Actually you're on the wrong side....hell your toilets even flush the wrong way!
Believe it or not I had a toilet that flushed the wrong way in Texas. Also you ride a horse in the middle of its back so How is that RHD?
You can buy a sealing grommet or a bulkhead for any wire and put it any where.
If you pass an oncoming rider RHD style you're open to his sword arm so passing on the left was adopted, in some places it stuck.
paradox616
472
Melbourne, Australia
i don't know about where your from but here if we flush the toilet it usually goes 1 way, to go the "wrong way" is to imply that you had a turd shot out of the toilet at you...
goliath
Fears no evil!
Lancaster, PA.
Wow...there's a visual for ya!:aigo:
For the OP. - I drilled a hole in the fire wall to the left of the down pipe and up behind the glove box. I sealed it in place with a rubber grommet I had lying around the shop. It looks like it was supposed to be there.
CzA
99
Toronto
"I'm guessing you're very good with your right hand after that statement "
LOL, you got me on that one.
"real supra's are RHD...not converted to LHD to be sold elsewhere *snap*"
Well i guess mine is a fake one. If it were practical for the japs to have lhd, they would, but they don't. for someone like me now, it's a different story. I have driven a RHD car, it’s not bad, just something i would not chose if i had a choice.
