I recintly got my car on the road and I think I'm running a bit hot. I've been building from 90 degrees celsius to 120 degrees celcius. I feel like 120 is too high. Does anyone else measure by celcius? What is too hot?
			tissimo said:over 100*c is getting hot.. over like 110 is way to hot..
Mine hovered around 85-90*c
Rich said:+1
Your thermostat is shot, doesn't open (enough) anymore.
Shadow said:I recintly got my car on the road and I think I'm running a bit hot. I've been building from 90 degrees celsius to 120 degrees celcius. I feel like 120 is too high. Does anyone else measure by celcius? What is too hot?
Rich said:+1
vas85 said:How would you determine whether your thermostat is shot, and though I think I know where it is on the 7m (near the CPS little to the front of it).
Freshmaker said:To test: Take out your thermostat. Put it in a pot filled with water. Bring it to a boil, and see if it opens.
I would replace it regardless if I had it out though.
soapra said:Naw, It's your electric fans. It's so hard to crack a head and/or blow a head gasket.
