So yeah Brought my car to the track and the turbo went out and they didnt even let me run cuz of an unknown leak. I was like wat fu**in leak?!?!? look down under the ground and there is a huge spot of oil i thought it was my powersteering pressure hose again. Checked oil and refilled it in the motor and powersteering so I could make it home. Get there change turbo yada yada then i figure ill try to locate the leak well i found it its actually leaking from the pan gasket right above the rack and pinion on the fricken drivers side!!!! How the hell is this possible??? Also I searched oil pan and didnt come up with any threads so yeah...............
