Oil Leaking from HG area!!!
LEGNA
80
CT
I finaly put my 62-1 and cometic hg gave it run at 10 psi.....no problem no crazy temperature but when i push it to 1 bar or greater , presurerized oil leaks almost all around the hg area could it mean its time to rechek the arps ...10 days ago they where tighen to 85 and today this happens..any suggestion..
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i would re-torque em, i've never heard of arp's not backing out after being installed... they've always needed to be torqued a 2nd time, so i'd check that asap
supra90turbo
shaeff is FTMFW!
32
MA, 01440
They need a re-torque if they've never been heat cycled before.
Read: If they're brand new.
You generally won't need a retorque if they're used, but always check.
sleepersupra
i hate this car
Nov 5, 2005
311
Broken Arrow, Ok
here we go again, i posted a question about retourqing and got alot of different answers....in conclusion just recheck them it takes less than an hour
just my .02
I retorque mine even if they're used but I'm old and cynical ;)
LEGNA
80
CT
Brand new and 3 heat cycles
LEGNA said:
All the rivets seemed to clear so no rivets where taken out !!
Including the one above the CPS? I assume the Cometic is new...did you use a spray coating on it?
LEGNA
80
CT
NO coating but i have reg temp and no over heating and no coolant leak i think it might be the dip sick thats misalined or the end of the oil return line from the turbo that maybe is not tight... lets wait till she cools down
Yeah...if the oil line is not tight on the bottom of the turbo, it will spray oil from the pressurized side.
LEGNA
80
CT
Oil Lines are tight ...so the last thing that might be it would be a crooked oil dipp line ..
