oil cooler
Status
Not open for further replies.
Adjuster
I like the RX7 unit, but it's not easy to fit this bugger anywhere you want.
Note the center support is history, and what's left is a custom modification that just happens to use the top part of the stocker, and some brackets left over from another oil cooler that I'm now going to put on my A8 transmission cooling circut.
The RX7 setup is fabricated aluminum end tanks, and radiator style tubes with a built in thermostat. Works great and holds more extra oil too. (Just hope you have a place to mount it.)
shaeff
Kurt is FTMFW x2!!!!
11
Around
11x8 B&M cooler, 180* B&M t-stat. :) love it. mounted it to the coolant resivour bracket, and center support. gained +20psi on cold start, and +20psi at cruise. i also relocated my oil filter to near the passenger side tow hook, and the filter is about 2.5-3x the size of the stocker.
-shaeff
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
hummmm i ran my oil cooler b&m trans cooler with no t state and i got pretty mucht he seam temp and warm up i usely get
ps this is going by pull dip stick out use heat tester gun and test it
i notice not to much of diff the b&M took temps away about 10c
now i don't drive my car in the winter so i really don't have much to worrie about
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
-shaeff
Think you could post some pics of that cooler and how it is mounted?
Thanks
Wayne
NashMan
Aug 5, 2005
4,940
17
Victoria BC
this may be odd but i have cut a rx7 oil cooler in half and found no t state
when mine dry rotted out
Status
