This started after I dropped the oil pan to shim the oil pump 3mm.
I'd be driving around, and stop at a stop light or stop sign and all of a sudden the car is engulfed in smoke.
I had a friend follow me once to see where it was coming from, he said all of it was from the exhaust.
I've checked my dipstick many times, before and after driving, and it hasn't moved from what I can tell. All of my other fluids are full also.
It definitely smells like like oil burning.
Last time I had the exhaust manifold off to fix an exhaust leak, I saw that either the 4th or 5th exhaust port was a little moist, like maybe oil or something, but didn't think much of it.
Head gasket was recently replaced with a cometic & arps, valve seals replaced and valve clearances checked/adjusted.
Turbo was also recently rebuilt/upgraded to 57trim.
The only thing I can think of may be piston rings, valve steam seals, or turbo seal, and 2 of those are new.
I also took the intake pipes apart to check for oil in there from the pcv system, and it is pretty clean, just a tad of oil.
