no power very slow
bis_1315m
197
charlotte north carolina
Hey everyone my car has for some reason started to drive very slow like 15mph I have no codes and everything was working great the other day 2 things have changed about the car 1 is I put an apexi filter on the car 2 is my heater hose broke and sprayed coolant everywhere and the spark plug galley is full of coolant so if anyone can tell me what's wrong and what I can do to fix this would be greatly apreciated oh the car shakes very hard at idle and sometimes dies when going to put in gear thanks for your help in advance
Michael
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
there's your problem... ;)
:rofl:
Check your plug wires, make sure they arent saturated... They may look dry, but they can act like a sponge...
Second, you said you werent pulling codes, but it sounds like it may be an afm issue... Perhaps when you were installing your filter, the afm plug came loose, or fell out... Or it may have a loose wire...
bis_1315m
197
:rofl:
well when i was installing the apexi filter I accidently hit the honeycomb on the afm and it kind of pushed the mesh together not sure if it makes a difference or not but whats the best way to empty all the coolant out around the plugs without taking everything apart
bis_1315m
197
hello Reign Maker are you there I know your busy so thanks for the help anyways
Michael
bis_1315m
197
Poodles said:
screwed up honeycomb = bad AFM
water in plug valley = bad misfires
well I mean the honeycomb doesn't have a hole or anything just a little dent in the middle but if that's the problem I can change cuz luckily I have an extra 1 laying around thanks that sucks though I thought about that but wasn't sure if it would make that much of a difference thanks alot for the heads up
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I'd say the coolant with the plugs and wires is your problem. If you have a wet/dry vac, use that. Or if you can drive to the closest car wash that has the high power vacumes, use those. Or if you don't have either, a towel and screw driver. But, I would change out the plugs and wires.
As for the honeycomb, I don't think that it would make that big of a difference. But like Jake said, maybe the plug is loose or your AFM electronics are bad.
the honeycomb straightens the air so it can properly make the vortex that read the airflow, if it's screwed up, the vortex won't work right and it will read wrong or not at all...
bis_1315m
197
alright I'll replace just so I can sleep better at night thanks alot
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
What those guys said... Sorry I couldnt reply fast enough... ;) My comp is a retard and now and then it likes to reboot for no reason...
Replace the honey comb, to be safe... Use a wet/dry vac and/or lots of good paper towels, then let air dry over night at least if not longer... Make sure to remove the valley cover, its being held down by 4 14mm allen head bolts...
bis_1315m
197
Alright but just wondering how do you remove the honeycomb from the afm without damaging anything cuz I would much rather change the honeycomb than the other afm I have in my garage becuase it's so dirty and the one in my car is in great condition except for what I did today thanks alot
