So i have 1989 toyota supra..the actual production date is late 1988. Anyway the window was giving me a hard time and it looked kinda ragged so i decided to buy 2 used doors. the doors i bought were 1990. The driver door i bought the guy had cut the plug so i had to splice in all the wires from the new door to my factory harness. all the wires matched up except on his door there was a extra black/white wire.
So i turned the key and tried the window and it went down slowly. I do not have the door control unit box hooked up cause mine did not fit on the new door. so i order one for a 1990 supra. So at this point power still works to everything.
HERES WHERE IT GETS WEIRD.. 2 days later. So the new Door control unit box came in and i plugged it right up and BOOM no power to windows, seat or mirrors. Im assuming its some type of fuse maybe but i do not know where. I used a test light and there is power going to the door control unit box.
All fuses in the engine bay are checked, and i checked the ones in driver kick panel. and even the fuses that are in the passenger kick panel.
The ones that are not been verified are the big box ones because i do not know how to check those.
Thank you in Advance!
