Ok just to start this off I did check what codes the car is throwing. Here were my findings.
32- HAC Sensor Signal
51- (This one is probably because the entire AC System was removed by the PO) Possible TPS issue.
52- Knock Sensor
Now that we are passed that I'll describe the problem.
First it starts up fine with every turn of the key, never any trouble. It idles like it has always idled for the passed 3 years, smooth around 1k(yes I know its a little high but it hasn't caused any problems for years). When you drive the car easy it accelerates easily with no hesitation and rpms climb smoothly. This is with shifting no higher than 2.5k for gas saving driving.
Once you start getting into boost however it has no power like it just flat lines. I can hear the turbo spooling like always, and the bov expels air when I let of the throttle, once again like always but there is no increase in acceleration or power. In fact the rpms almost stop climbing all together when the boost starts kicking in.
Its a stock turbo with 3in IC pipes and IC. Both installed by PO and been on the car for the last 3 years. The Turbo was replaced about a year and a half ago with a used turbo and new seals.
On the way to work yesterday it ran strong and pulled hard like always, then after 8 hours of work on the drive home it started acting like described above. I checked the couplers on the pipes and they were all attached fine. Also I do not have a working boost gauge in the car so I can't say what the boost is climbing to when I drive.
Please can anyone tell me what the issue most likely is?
52- Knock Sensor
