Hey guys, 2 things wrong with my 87. One: No heat, fans work but blows cold air. I would assume the heater core is just bad but I wanted to know if there is anything else I should check before I take out my dash(LAME!:3d_frown
. Two: Power steering whines like a mofo and I would definantly like it to stop. Again probably simple (replace pump) but I wanted to check before spending the cash. Also when I replace the pump, do I need to bleed the system after I replace it to stop air from getting in? Thanks guys!
