While I'm not entirely stumped... yet... the options I'm left with are all rather... distasteful.
So, here's the story. The vacuum operated valve that allows hot coolant into the heater core doesn't open under normal operation.
The valve is fine - if I bypass the VSV and feed it straight vacuum, it opens normally.
The VSV is fine as well. Swapped with a known good unit, same behavior. It's just not getting any signal to tell it to open.
I'm not entirely positive which coolant temp sensor this is dependent on, however, most of my sensors are brand new from Toyota anyway.
What I haven't checked:
- Wiring continuity. It's possible that I have a short / break somewhere in the wiring. Not entirely likely, as I rebuilt the engine wiring harness a few years back, but I won't rule this out.
- Circuit breaker. The TSRM mentions a circuit breaker in the AC section. It doesn't, however, mention *where* this is. I'm sure I'll find it eventually... passenger side kick panel, perhaps?
- The climate control unit itself.
Anything obvious that I might have missed?
Any tips for what affects this VSV would be appreciated as well.
Admittedly, I could just leave the VSV out of the equation, or bypass the valve entirely, and it will work fine. However, I'm a little bit picky about the details, and I like everything to work the way it was designed, so I'll be a fair bit happier if I can figure this out.
