I have a bit of a headache amongs me. My 87 NA Auto has no heat (also no ac) aswell as a slight coolant leak. I found the leak and it is coming from the drivers side heater core hose. I think it is juat a bad clamp that isn't tight enough. I know the heater core isn't clogged since I was freely able to flush water and air through it, blowing everything out. The drivers side hc hose however, gets a bad kink in it and doesn't seem to allow proper flow of coolant to the heater core. 1. does anyone know who I can buy a quality hose from? The HVSV also doesn't open when I change temp or fan settings. Ive tried to by-pass it but still no heat. Maybe, Ive done something wrong in that process. Ive followed the sonic tread instuctions. My thermostat is new to and have no problem with the temp gauge. let me know your thoughts please
:aigo:
:aigo:
