Ok I did (and am still trying to find more info) my research and I just want to confirm what I have found.
Situation:
Car is down right now awaiting new IC due to several leaks on stock system. During browsing I came across a few BHG threads and have concluded that my Supra is exhibiting signs of head gasket leakage:
1- Coolant spillage out of overflow when engine is revved while car is cold.
2- Nasty smelling brown coolant with gunky residue in overflow tank despite several flushes (note: no oil in coolant at all, this I am sure of)
3- Gurgling noise on start-up (could also just be air in the coolant passages)
Additional notes: The engine is a swapped in JDM 7M-GTE. I have no idea what the situation with the headgasket is. I have driven it approximately 7-8k miles since the swap with various issues (refer to build thread)
After the swap, the mechanic used green coolant, which I replaced with Toyo Red about 1.5k miles later. However I can not get the coolant to flush clean, there is always brown sludge that settles and congeals in chocolate-likeness
Actions to be taken:
Now these may not be SURE 100% signs of BHG, but they are certainly not normal, so I have decided that I am going to nip the problem in the bud to be safe. I want to replace my headgasket with an oem one and replace the bolts with ARP bolts and torque it down properly. Here is my understanding of the process, please advise if I am missing something:
note: I am keeping this engine stock and want to keep it running safely until I can afford a 2JZ-GTE swap evil2, so stock oem gasket and ARP bolts should be plenty
Remove head:
----drain coolant
1- as per tsrm, remove exhaust, intake mainfolds, turbo, etc etc
2- clean head
3- chase block threads
4- check block, head, intake and exhaust manifolds for warpage
5- apply oem HG with fipg at locations specified by tsrm
6- replace head and bolt down per tsrm with ARP bolts to 75 ft-lbs
7- replace all the peripherals as per tsrm
----add new coolant
enjoy?
And if I read correctly this is a process that, with proper preparation, shouldn't take 2 guys more than a couple days to perform. And to double check, the engine doesn't NEED to be pulled to do this, correct?
Parts required for prep:
OEM headgasket (driftmotion ~$90)
ARP bolts (buddy of mine)
New Coolant
Tools to include: 12mm x 1.25 thread tap (driftmotion $8)
Any feedback is appreciated, I've read so many threads on this subject I got an information overflow so I decided to put it all into one thread concisely. Thanks!!!
Situation:
Remove head:
----drain coolant
2- clean head
----add new coolant
enjoy?
New Coolant
