xarewhyayen said:Niacin is a suppliment that actually flushes your system.. it is said to help flush your body out in preparation for a drug test. I believe it does it by speeding up your metabolism, but im not totally sure.
Edit : http://www.nlm.nih.gov/medlineplus/ency/article/002409.htm
suprasport91 said:well your fine if its jsut urine, but remeber you need diuretics, and lots of water, it will speed up the expulsion of toxins, then again, it is in two weeks so you should be fine, haha just be safe
lagged said:haha what toxins? metabolites of THC are lipid soluble. so, thc metabolites will be stored in your fat cells. exercise and plenty of water will help to work those out of your system. if you will pass or not depends entirely on your metabolism and how often you smoke. once a month? you should be fine, more frequently than that, youre pressing your luck.
also, when pissing into the cup make sure the sample is from the "middle" of the stream. at first there is more garbage, towards the middle of your piss session is the cleanest urine, then at the end it gets "dirty" again.
