New power!!!! 404HP 405ft lbs @ the wheels CT26 on 17.5lbs
Devin LeBlanc
1,830
Las Vegas NV.
Thanks, Heading to work and going to throw the car up on the dyno after we get a few other cars tuned. We have 3 cars to tune today including mine so hopefully should do some better numbers.
Fuel pressure is holding now so should be good for 400 unless I run out of injector. Fuel pressure is set at 60PSI base and holding now so should have some room and need to pull fuel hopefully.
New DW300-1 pump installed.
te72
Classifieds Moderator
6,625
9
WHYoming
I hate you guys and your E85... I'm literally sharing a border with NEBRASKA and we (to my knowledge) don't have even ONE station with E85 at the pump.
Nice numbers man, you'll have to update once you get the fueling issue figured out.
Devin LeBlanc
1,830
Las Vegas NV.
Fueling issue is figured out. weak wiring and not enough flow from the single walbro. New wiring installed and Deatschwerks 300lph pump installed!
Dyno'ing within a few hours
Devin LeBlanc
1,830
Las Vegas NV.
eh idk about that. Injectors maxed timing is at 15 degree's BTDC I think Im pretty much at the threshold.
---------- Post added at 09:04 PM ---------- Previous post was at 08:50 PM ----------
Oh yeah, it doesn't hook until 85mph in 3rd gear :D
Got some vids my friend took out in front of the shop after we finished tuning
Smartparts
146
CT
Those are some impressive numbers. Did you bypass the knock sensors just by unhooking them or what?
Van
87t Hardtop
Mar 26, 2006
974
Oak Grove, OR 97267
Devin LeBlanc;1745360 said:
Made 396HP 398ft lbs @ the wheels on 18 psi. Injector duty cycle is at 88% 12.1 AFR by redline
12.1 is a little lean on e85... Stoich on e85 is like, 9.765:1, as I recall. Van
I think I'd be tearing my hair out trying to hit that magical 400HP/400ft lbs numbers :rofl:
Still, regardless of numbers, looks like fun :)
Devin LeBlanc
1,830
Las Vegas NV.
yeah Ill get there, Probably going to 1000CC injectors shortly lol Then Ill be able to push 20 psi. I would love to go to a dyno jet to get a 400HP number but I don't want to pay as our shop has a dyno in it that I can use for free so its whatever lol
supranasty
Yo Daddy
Apr 12, 2005
374
jamaica ny
396hp on any Dyno with a automajic Trans using a CT26 is BIG BALLS.
manual trans do it easier. Impressive Devin.
No one wants to call that a probe. lol
You are gonna step up the game big time at the track...:1zhelp:
Great work
