new 2JZGE-T and Master Power T-70 numbers
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Hey, I'm sure I'd be angry if I was older than the dirt I [strike]stand[/strike] hunchoverleaningonawalker on, too.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
tturnpaw;1033633 said:
what grind are the cams? isnt your cr like 8.9:1?
very roughly 264's. Approx 8.9:1 is my estimation. I haven't taken exact measurements tho.
10secdream;1033671 said:
Wow excellent numbers. What are your supporting mods?
IJ.;1033730 said:
I'm one of his supporting Mods :D
haha! What Ian said.
2JZGE
cams
870cc injectors
Stinger EMS
Bosch 044 fuel pump
Hg & ARP's
Sethron FFIM
Q45 TB
2.5" hotside IC pipes, 3" coldside
ebay 4" FMIC
XS Power manifold
knockoff wastegate
Master power T70 .68A/R
full 3" exhaust
Devilsown meth. injection kit
Os Giken quad disc cluth
Plugs : BKR7E's (6097) @ .026
I think it still has more in it.. I think I can hit that 700whp mark with a larger hotside, and a less restrictive exhaust. FWIW I'm happy with the car's power now and will be leaving the motor alone until I get an itch.
Looking at the dyno graph, I'm currious as to the drop in tq/hp in the upper RPM range, does anyone have any idea what would cause this?
@what psi does your meth injection kick in? I was thinking of getting a kit for my 1.5 and have it kick in about 17psi. What do you think? I only plan on running 20psi of boost though. Thanks.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I have mine kick in at 16PSI, I used to have it kick in at 18PSI. I can't tell any difference whatsoever. LOL.
I think that 17PSI sounds pretty good. When I look for a place for my meth to kick in I'm looking for a few basic things.
I run a lot of methanol, so I make sure that it won't be too much fuel at once, so ideally there will be no bogging.
I make sure that where the meth cuts on there will be no detonation on pump gas alone.
I also make sure that the cut-on PSI is at least 1PSI away from my target boost, this will keep the pump from being cut on/off if my boost was unstable.
Sounds pretty reasonable Scott. I may set mine up at 16psi also. I doubt you'll be able to feel any difference, but the peace of mind is priceless. Is yours set up through your standalone? I've heard I can get the Stinger to control this, but I'm not sure how yet. I'll have to do some research on the subject. Congrats on the awesome numbers.
My cr calculated out to 8.67 so I should be good to go with 20psi with no problems.........crosses fingers. When I dyno for max numbers, I probably just do two or three passes at 25psi on 110 octane.
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
2JZGE
cams
870cc injectors
Stinger EMS
Bosch 044 fuel pump
Hg & ARP's
Sethron FFIM
Q45 TB
ebay 4" FMIC
XS Power manifold
knockoff wastegate
full 3" exhaust
I would say the drop off is caused by the 264s...i bet 272s and an .8X-.9X hotside like you said would make the world of a difference in your top end. Sounds like you have plenty in the rest of the build to do it. but again, never built a car with that much power, and im no expert.
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
gilberjj;1034270 said:
great numbers, i loved my mp t-70 when i had it.
and I'm lovin' it now :icon_bigg I said it in your build thread and I'll say it here Scott, AWESOME!! I showed the dynosheet to some guys at work and now the expectations are set even higher for me :3d_frown:
quake
toyota tech
Apr 13, 2005
619
r.i.
2JZGE
cams
870cc injectors
Stinger EMS
Bosch 044 fuel pump
Hg & ARP's
Sethron FFIM
Q45 TB
ebay 4" FMIC
XS Power manifold
knockoff wastegate
full 3" exhaust
got the hot side you need...
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Yea man, I'll be there. Hit me up.
The supra has me stumped, it's getting spark and fuel.. that only leaves comression :(. I hope I just did my math wrong for the valve shims.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Have you checked compression? Timing on the right side...lmao sorry had to ask! Why did you have to change the valve shimming? Same head right, same valves and cams right? Or were they wrong before?
Well let me know if you need a hand and I will come out and take you for a boost ride to lift the spirits...lol
Seth
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Seth
The same head, cams, everything.. but they were over .01" out of spec. hopefully I just idd the math wronggggg.. blah.
Plugs are also fouled, maybe that could be doing it? It has a terrible miss. Timing is all good.
