NEED wiring help!!!
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
This is the pinouts for the jza70 ecu. I didn't see the map sensor on there though. Maybe it's coded differently.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
still cant see the MAP sensor on this one either
you might just have to trace the wires
EDIT: i believe its on the T connector (mine is a green wire) but i dunno if thats just mine tho
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
My wires where all cut so i cant really trace them back. W2 is the the green with black? Where dose the black with red and brown go? Would they be all together?
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
Im thinking its pins (W1)-"vc-Vac sensor", (W2)-"PIM-Vac Sensor", and (W9)-"E2-Earth for 1,2,3,4". Can one confirm with that?:1zhelp: I really dont want to kill my ecu or my map sensor, so i want to be kind of sure on where they go.
Thanks for all the help so far.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
It IS the PIM pin.
