Need Help With Code 24 and Code 51
JDMMA70
2,550
Houston
^ What the title says.
24
Intake air Temp Sensor Signal
Diagnosis
Open or short circuit in intake air temp sensor signal (THA).
Trouble Area
Intake air temp sensor circuit
ECU
51
Switch Signal
Diagnosis
No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
A/C switch circuit
A/C switch
A/C amplifier
Throttle position sensor circuit
ECU
How do i go about fixing these?
Thanks
~JDMMA70
Justin
Speakers?
Spokane, Wa
Code 24 is the air temp sensor inside your afm.
The Code 51 is probably a poorly adjusted, or dirty, TPS
Thanks
~JDMMA70
JDMMA70
2,550
Houston
Could another code say Code 22 set off Code 24? The wires to the water temp sensor snapped so my dad is going to sauder them together tommorow. Also would these codes attribute to my car dieing everytime the throttle is opened, or would that be my timing. Right now since Me and Steven89 installed a working CPS into my car and set the timing to 10'. For a second question as I tried serching what's the correct timing for a Auto 7MGTE.
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
i have the exact same problem. and supprisingly enough (i'm sure it don't make a difference my wire to my water temp guage snapped aswell although i fixed that today and am going to play with the tps tomorrow)
