need 4.30 info!
jaydm16
76
Im considering swapping the rear out of an N/A. Im pretty sure i need the sport package to get the lsd 4.30 pumpkin. The pumpkin is a straight swap, correct? Also I dont know how the supra's speedo works but i would imagine like most domestics it will kick the speedo way off at highway cruising. Any advice on this swap would be helpful thanks!
shaeff
Kurt is FTMFW x2!!!!
9
Around
your speedometer will be a little off. its a direct swap. slap it in and go.
-shaeff
Jeff Lange
Administrator
4,919
4
Sunnyvale, CA
jefflange.ca
LSD was part of the sport package, or available by itself. It's a direct bolt in, but yes your speedometer will read incorrectly, can be fixed by changing the speedo drive gear with one from an N/A.
Xtreme
138
Lebanon, OR
going from 391 to 430 is definitely a noticable difference, will accelerate harder, but at the cost of top speed. And just take the drive gear out of the car you get the diff out of. Or any other 430 car, for that matter.
Xtreme
138
Lebanon, OR
not sure about top speeds and 1/4 mile speeds, because you could still do a 30 sec quarter in a geo, even with 430 gears. It should improve your time (with a healthy car) by at least a half a second
