My new wheel combo, (few questions before ordering)
Dec 3, 2003
6,653
Canada
New wheel combo.
I am looking for people that have pics of a 315 tire on the rear of a MKIII Supra. I know, the body may need to be widened a little which wouldn't be a problem.
My new wheel combo I am going with is.
255x35/18" / 9" front
315/35-17" / 11" rear
How far out can you pull the fenders before you have to cut them?
I would like to see some angle shots if anyone has them so I can see just how far the wheel or tire will stick out from the body. Please list specs of combo when posting. :)
Thanks in advance
Duane
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i had 315s for a while, but the wrong offset so the tires stuck out, i could post up a pic if you want, the wheels were 17x10.5 with a 27mm offset iirc
jugodegolf
Phoenix,AZ, United States
brandon has same rims & setup just finds the runs the 315's.
Duane his just fill the rim a little bit more than mine.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Duane has some camber though. I'd be sketchy about rubbing the coil over. I actually was rubbing on it once on my MK4 NA's with just a 245 tire. I think something closer to a +40 offset, with a rolled flat fender or trimmed fender.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
what offset's are available for the rim's?you might want to run alot of offset with a wheel that wide
Dec 3, 2003
6,653
Canada
Anything I want. They are being custom made for me.
Thanks for posting the pics :) I want an 11 but think they will stick out too much...hmmmm
Duane
tsuper92
supra addict
Apr 7, 2005
1,376
mass
looks like you got some work to do.you need to get that tire close to the coilover.being able to play with the offset should help.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
judge what size do you have on those tt wheels? or are both of those in that pic yours? im confused. the car on the right has 315 with tt wheels? and the left?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I think he was just showing rim clearance. There is no way that is a 315 haha. Duane I will calculate some sizes in a bit and see if I can think of a good offset for you.
jugodegolf
left stock right tt 295's i believe they have been replaced. Brandon sweezes 315's on his tt's n looks okay. I tried pm him not heard back yet. both cars are mine.
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
i vote you pull the front and rear so you can fit a 11 in the back and a 10 in the front but thats just me
the group a cars were 18X12s just saying
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
For 17" drag radials, the only options seem to be a 315 or 275, so Duane and I were talking about going with a 295 street tire. How much more traction could he gain with a 275 DR compared to a top-of-the-line street tire? Keep in mind, he's pushing over 650hp on the street.
