my new 90 turbo hard top....gimme boost!
BrandonW
1,300
N.J.
looks like you will have everything done somewhat soon
assembly should start for mine on tuesday
i know i have and you assisted me with doing everything right but im still going to keep my fingers crossed for the hg to seal :aigo:
BrandonW
1,300
N.J.
yo might you have a extra one of these laying around?
its that tube coming off the back of the head, really the top half that looks rusted in the picture, that one is bent up
gaboonviper85
3,236
Northeast Philly
Question #
1. The vsv that controls the fuel pressure regulator...is it acceptable to remove this when using an afpr when performing bpu's? What are the possible negitive effects if removed?
2. The two vsv's have different part #'s but are they interchangeable? I've noticed that with no power to them, they route the same..
3. Does anybody have detailed pics of where and how exactly they mount under the intake?
Thanks for lookin!
gaboonviper85
3,236
Northeast Philly
Another sunday night of work
got iscv mounted with new rubber gromet+gasket
iscv/throttle coolant lines situated
got valve shims situated
routed some vac lines
Tested hood fitment with my afpr+bracket....I need to change it as it does indeed hit the hood.
Pics
my timing cover...I'm feelin it
gaboonviper85
3,236
Northeast Philly
Well I've been wrenching all weekend so far and got a bunch done!
Reinstalled the bottom inspection plate between the block and trans (previous owner didn't do it......finished installing the egr system....installed charcoal canister.....remounted my afpr as it didn't clear the hood.....picked up my safc2.....figured out some wireing....got the stock oil pressure sender installed....
Also...had a friend run speakers from the entertainment center down to the garage and picked up my propane heater as it's damn cold out!
did some drinking:)
took the oil pan off my spare motor and indeed it is rod knocked:-(.
the crank looked workable but still not awesome....the rod cap nuts were finger loose so thank god it didn't pop a rod threw the block
gaboonviper85
3,236
Northeast Philly
jessemkiiis;1483970 said:
I demand more info ^^^^^ custom?
Nope not custom....
Cxracing : kit-7mgte-IC10-IC0010-25-A
ordered threw Zankoku performance (misc vendor on here) $400 ish shipped my my door with every pipe needed which is the only kit cx sells that has every pipe included even though they say all their kits include every pipe.
The 3000pipe replacement has brackets for the pcv pipe and iscv pipe.
