my Muspra
boostinprine
115
Carbondale, IL
yea, the intercooler doesnt need actual air flow. It has a water tank and small radiator in the front of the car to cool the water after it flows through the intercooler. I used a air-water because it eliminates feet of charge pipes, you can run ice, more efficient, and i already had it... It works really well, I have an overkill 10+ gallon tank in the trunk that will hold over a 22lb bag of ice and water. After multiple passes at the track in 90 deg weather, the intercooler is still ice cold to the touch.
I run W2A for a few years and :love: how it doesn't heat soak in stop start low speed situations like A2A does.
Only reason I don't run it now is once you get over xxxrwhp the hardware becomes HUGE and packaging it into a Mk3 is a problem.
Isphius
Supra-less :(
May 30, 2006
359
long branch
Awesome swap. Ive always thought it would be cool to put a 3sgte or 7m in my 2.8 camaro. the 2.8 was just so awfully underpowered. And thats an instant huge weight savings off the mk3, and opens a lot more aftermarket support. And 03bama, the SN95 is the name of the chassis for all the 94-04 mustangs, new edge is just what they called the new body work. And its still built on the fox chassis design. Most of the parts are interchangeable and all thats really different is the body parts. How fast is it? haha Oh and what did you do for a driveshaft? its an r154 right?
03bamaGT
288
Bham
Even though Ford did not release a Letter Number class for the New Edge, it is just accepted as the New Edge rather then calling it a SN95. 99-04 is the forgotten year haha.
New Edge would be proper for 99-04. My car is not an SN95, the curvy 94-98 would be.
Isphius
Supra-less :(
May 30, 2006
359
long branch
i remember reading somwhere that that is the chassis code for all those years. I guess i could be mistaken! BTW, how much does that car weigh with the v6? was it any lighter or heavier than the 7m?
