So here is the deal. anything over 20psi and i'm machine gunning bad. it doesn't matter if i'm on pump, methanol, race gas, etc. i verified using all different fuels and i have the same outcome.
i borrowed my friends ignitor and coilpack. Both are low mileage unit. my idle is get a bit better with the coilpack but i'm still having the misfire.
i'm running an AUTOLITE 3923 plug. gapped at .26 all my grounds are good, and i even added a couple of more... all grounds less than .2volts which is good.
the car is throwning no codes and she is pulling 21 hg of vac at idle. i ohm checked the plug wires and there all in spec.
primary resistance in the coils is within spec.. too bad w can check the secondary.
i put the car on scope and the firing lines look good. there a bit low,,, 3kv, however this is due to the tight gap. dwell looks good, and so does coil oscilation.
did a compression test and that is good as well.. between 160-155 through all cylinders.
i'm running out of ideas..... i know i have a stock setup for igniton but this is a new thing. and i know people are running higher psi with the same setup.
the only thing i can think of is excessive carbon build up in the cylinders. i know my motor burns oil and it always has. maybe i jacked my compression a bit and with the extra boost the plug cannot fire.
you would think to, because with a waste spark system the plug fires from the ground strap to the electrode providing a much more power spark..
i even used my snap-on ST125 plug tester and i'm good to 30,000 volts
so i'm at a loss here.. any tips would be great..
just nothing from jetjock
