My Black 91 Project
InvisibleMonkey
2JZ NO SPIT!
Sep 17, 2005
399
SNJ
Lmao I'm an awesome model. Chris is just hating on my sexy.
Car sounds so sick in person though.
Glad I made you laugh, RazoE. I like making people laugh. :)
BTW, that picture is going straight to facebook.
supra1008
1,179
Philadelphia
Oh yea. Um totally hating. Lol.
Thanks. I still need an exhaust though.
supra1008
1,179
Philadelphia
Changed the front brakes yest morning. Hooked up the boost gauge and the starter. Still need to do rear brakes. Flush brake system. And def need an exhaust.
supra1008
1,179
Philadelphia
Update... So ive been having a problem. At idle I run pretty rich around 11-12:1afrs. And when driving it it runs leaner than normal. Some people are saying it's because of the bigger cams and bigger turbo w a stock computer. Others are saying to put some miles on it and the o2 snsor will sort things out. Anyone with more input? Agree or disagree? On a side note I replaced the brake pads and rotors all around. Was definately in need of them. The backs were way wors than the front. I'll try to take pics before throwing out the old ones. I'll definately need new ebrake shoes!! Cmplete trashed!!! I'm guessing this guy use to drift or just drove around w the ebrake up. Idiots!!! The back right caliper was also seized horrbly! So I borrowe a used one until I buy some calipers for it. All I need now is an exhaust.
supra1008
1,179
Philadelphia
See... she runs. not running right though just yet... still having this problem of running rich at idle and running lean under load. I checked all the wires. I'm gonna go with the bigger cams. I'm thinking I might try to put the stockers back in just to see if thats the problem before I go buying a safc until I can save up for a standalone. I took her out on the road today for the first time since i bought it. Went to fill gas...was definitely needed!! Sorry forgot to take video. I took a few pics... i'll try to post that up later.
supra1008
1,179
Philadelphia
Filling up gas for the first time.
supra1008
1,179
Philadelphia
^ thanks! I hope mine could look half as good too. lol
I tried driving it to work the other day. Checked all the fluids and started her up. Checked for leaks. No problems. ran normal except for running pig rich. I get a couple blocks away and she starts overheating. So I pulled over to check if the fans came on, which they hadn't. When I started to trouble shoot i found that the fuse melted. So I jumped one of the fans straight to power to get it back to the garage. Another problem was that even while cruising I could hold it for example at 3k rpm (just cruising) it would completely lean out to 18afr. So just to get it back home i just kept getting on and off the gas and kept switching gears just to keep it from going compeltely lean an cutting off. I ordered a SAFC until I get a standalone so I can atleast cruise with it to the meet on sunday. *fingers crossed*
