Most Common Leaks for a MKIII?????
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
The difference between a Supra and a bucket?
The bucket doesn't leak..
These cars leak everywhere when not properly maintained.
Targa leaks, rear hatch leaks, power steering leaks, oil leaks at the valve covers, oil leak at the CPS, coolant leaks near the rear of the head, coolant leaks when you blow your HG, etc etc...
te72
Classifieds Moderator
6,612
7
WHYoming
Bwahaha... beat me to it man. Was gonna say, "is it a 7m? Then everything. Is it a JZ? Probably still a bit of everything.". Even a well maintained car can leak a bit here and there, I'm going to be doing my best to make sure my next shell doesn't have ANY leaks. We shall see how successful I am by this time next year I would think...
puerto;1780971 said:
well i know for sure my power steering leaks like hell.....fuck ill def make my shit not leak.
Good luck man. It can be done, but you're going to be replacing a lot of seals, and spending a lot of time pulling things apart and putting them back together. I think the number of leaks on a Supra directly reflects how (crazy), errr... dedicated you are to your car. :p
Turbo Habanero
4,229
Tucson,AZ
CrazyHorse26
Formerly Puerto
Aug 2, 2011
110
Long Beach, CA
well i guess im lucky then cause i have no rust in the spare tire compartment and i absoulutley dedicated to my car ands im definately going to make sure ensure there are no more leaks, even if i have to pulled everything out..ill do whatever it takes and get this car the level i want to be, which is showroom condition, so far everything is stock not to mention ive only swapped to a stock 1J.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
puerto;1781063 said:
i have no rust at all bro......ive checked everywhere....
You don't need to check everywhere. Just pull out the rear seats and the inside body panels beside the rear seats, and look at the seam on the inside rear fender well. If it's going to be rusty, it always seems to start there.
