Monster Performance Drag MKIII - 2JZ - Big turbo - Powerglide - lots of pics
SuperRunner
104
utah
suprakidd;1902125 said:
Car looks absolutely amazing. The center section of that turbo looks neat, btw what's the specs on the na-t 2jz in your sig?
Thanks.
The NA-T was stock motor with a 76mm turbo. Made 916rwhp(GS300 NA-T)
SuperRunner
104
utah
SuperRunner
104
utah
we are going to weld the o-ringed cyl to the top piece, and T-off from there and come up from underneath, but still above the water pump
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
I saw this car getting the motor pulled on the grass and talked to these guys at TX2K12. Cool ass group of guys,bad ass car and a even cooler tow vehicle.Good luck with the build it looks nice
SuperRunner
104
utah
Thanks
We aslo hope to be at TX2K13, but we still have a lot to do on the car and little time to do it, and the car will be fully untested. :( Regardless it will be a blast.
cklynboyz
Building A Beast!
Feb 24, 2012
68
Brooklyn
Hey Great build. Can I ask what size slicks u running? I would like to know what's the max size that fit a stock MK3. Thx!
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
28x10 on a 300zx rear rim is perfect.. keeps it under the car too.
Tun_x
Built to do the NASTY!!
Utah
We wanted all the sidewall we could get.. I failed to mention that it is the 10.5W tire on a 10.3" wide wheel wich is significantly wider than the standard 28"
SuperRunner
104
utah
Nice piece from Vibrant. This Vanjen clamp will eliminate blowing off couplers and make for very easy R&R. No more silicon hose and t-bolts.
ATF's billet SFI GM adatper
Modified lower radiator neck and oil return to get around the complex exhaust manifold
Modified upper radiator neck to clear the huge GT55 style compressor housing
SuperRunner
104
utah
TweeT91109;1929802 said:
Are you planning on coating these with anything? I feel like the manifold is so close its a must.
Most definitely, but we are going to heat cycle it a few times first.
TweeT91109
738
Tampa, Florida, United States
very nice, looks like a very fun car to drive, I have come to the conclusion to go 2j in my mk3, but nothing like this. Just a bisic swap for now get it running good as stock as possible then start upgrading from there. Already have a block and mid sump oil pan set-up that im sitting on, but my just get more swap parts together, and then man up to purchase a aristo motor set.
