MKIV igniter
shaeff
Kurt is FTMFW x2!!!!
11
Around
It was likely dual MKIV ignitors, in an effort to run a C.O.P. setup using 1jz coils. bigaaron made it work that way, if I remember correctly.
No, it's not worth it. If you're interested in worth-while, aesthetically pleasing, and fully functional ignition modifications, you should check out this link:
http://www.supramania.com/forums/showthread.php?t=39059
However, that's only an alternative to the stock coils. There are other ignition enhancing units out there that work on our cars, but it really depends on what you're looking for.
