hey guys what do you think of putting the mkiv brakes(calipers and rotors) on a mkiii. would it just be a direct bolt on application? and would it be worth it or should i just go with an aftermarket kit?
thanks guys
			thanks guys
IJ. said:I run Mk4 TT Rotors F&R here and it's far from a bolt on to do it correctly....
IJ. said:1st issue is the front rotors won't fit over the Mk3 Hubs you need to remove 5mm.
Next is the Centre holes in the Mk4 rotors are larger so spacers are needed, I had the front and rear suspension removed at the time so I ended up press fitting a spacer to all 4 hubs and machined it to size so it's perfectly concentric.
I used AP Racing 4 piston callipers so had to make mounts for them anyway so for me that was a non issue.
As I understand it the rears are close and NFI on the fronts as I've never had my hands on a set.
AP Racing 4 spot Callipers with Mk4TT DBA Rotors front and rear.
