MKII foo
sarinas_dragons
application developer
Oct 5, 2007
89
Parkland, WA
Some I know are members here. Some may know me too.
I generally avoid moderation and prefer medication...medification..dammit...modification.. there.
I get into trouble but will try to be good.
Mostly a 5/6MGE guy. But I have good study habits. I hear old guys fine.
I made this.
It mounts these-
http://www.extrudabody.com
for this-
http://www.forums.celicasupra.com/showthread.php?t=34267
http://www.forums.celicasupra.com/showthread.php?t=33450
I hope I like it here.
Kangae
Buzzin' Half Dozen
Sep 13, 2007
249
Utica, New York
That looks pretty cool actually, its always nice to see guys who make thier own stuff...really though not much I can say otherwise, I'm not reall up on 5m/6m tech...
I do like mk2s the second best out of all supras though...
Anyway welcome to supramania, feel free to have a look around.
sarinas_dragons
Oct 5, 2007
89
Parkland, WA
Thank you for the heads-up on pictures.
But hardly anyone likes being the oldest one at the party. I'm 48 and a grampa. Wait 'til you're old.
I have done alot of work understanding what Toyota meant in these old designs. I have all the piston volume versus crank angle per 720 degrees posted. I've done the component weight versus rpm studies for your bottom ends. The intake charge speeds, ignition studies, and a speed and accelration per 720 degrees for your bottom ends is not posted here it's posted there.
I've posted rpms and shift points overlaid to compressor maps for the common upgrade turbos.
I don't think it was the intro, bro, it is chilly in here.
sorry about that pic size, I'll re-size
Junkie
Another Old Guy
Aug 22, 2006
PacNW - Area 51
I'm sure there will be a bit more interest Kenny. Just going to take a few weeks ;)
Change of plans sorta --- Initial startup/testing will be on the Silver cars engine. A bit more compression than the dyno mule, but better than the Red cars engine.
sarinas_dragons
Oct 5, 2007
89
Parkland, WA
huff huff huff hufff ffff hufff I barely got back her from my first post, sheeeeeeessh..........that did not go well, I though it was a good joke though.
shaeff
Kurt is FTMFW x2!!!!
11
Around
sarinas- it looks like you're quite the fabicator. :) looks to be top quality work, too! :) welcome to supramania. i hope you can find any info you're looking for, as well as contribute to our community.
keep up the good work!
dirtlord420
just here
Aug 1, 2005
371
tn
what other mods will you be running? i would like to run a set up like this for my 85 but with a 7m. i wish i had the time to check this out when i was up there.
sarinas_dragons
Oct 5, 2007
89
Parkland, WA
We just have to install and do a back up dyno initially. All the TE,VE, and ME studies are there and the math for what I calling an improvement.
Besides you were supposed to buy me a latte and you said " ummm...we were washing the car at the family reunion and you're probably a pedophile like on tv....." so now you have to bribe me. And it better be good. Ask Tanya how I bribe her.
sarinas_dragons
Oct 5, 2007
89
Parkland, WA
You have two hundred percent more posts than i and I feel your power.
I feel absolutely hypnotized. I always underestimated the importance of the influence of the number of posts.
When I'm brave enough will you let me post?
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
lol welcome aboard kenny, those itb's looks like their gona be sick
are you puttin ghtme in a plenum or running them in a n/a style?
i'll admit not alot of us make it to this section of the forum.
sarinas_dragons
Oct 5, 2007
89
Parkland, WA
My application developer deal is to dyno first, then install and do a back-up dyno. In having done the TE, VE, and ME calculations I understand where the stock peformance is to occur.
But removing the stock intake tract is not without fault. True Toyota restrictor-plated the intake. But they achieved very high VE of 111% at the torque peak of 4400 with accurate pulse tuning acoustic supercharging.
At the stock hp peak there is only a VE of 104% and it was only possible by pulse tuning. The stock cam duration is so conservative that the port timing is brief.
I show a 15% horsepower gain can be achieved on stock cams with standalone. Aftermarket manufacturers claims of improvements must show benefit. A 15% improvement is a worthy sales tool. But that is only the beginning.
I have a selection of cams and headers to test. Then my massaged head. Sorry. Proof of benefit of our set of forged rods and pistons. Titanium valves upgrade proof of benefit. The studies are completed and the ITBs and manifold are the first pieces of the testing to be undertaken.
The developement team will continue with testing as I assemble the 7MGE manifold. The 7MGTE customer has until spring but is eager. I'm going to follow some new ideas about cylinder versus runner and plenum volumes with the turbo manifold. The ITBs are a far bigger advantage than is understood.
