MK3 1.5jz vs Roucharged Shelby
11 psi? Why would he be running 11psi? Apparently that's all he needed, but I'd been running at least 15 or 16 psi depending on his turbo. I personally run 22 psi, but I have the added benefit of meth injection.
Good kill though.
LordDigital
360
Chicago
Good kill though.
JDM 2JZ-GTE Injectors and a big turbo would cause fuel cuts over 12psi on stock ECU. I'm running 12.4psi resulting in 390@wheels which is not a big number ,but the powerBand with the BC cams is just perfect for the R154 - and this is what makes the big difference in the "real-world performance"...
Hahahahaha Scott can't see the video...........oooops, was my inner voice typing out loud again.
johnd
278
Ont. CA.
I don't know about that one, usualy u will never hear a i6 exhaust note over a screaming V8.
RacerXJ220
Interdimensional
Abalama
It was a real Roucharged stage 3 Shelby, and the Supra was at 11PSI. It does creep up to 14 for the last 1K rpms usually, but I was on wastegate only. I don't think the iridiums like long sustained pulls because I had spark blowout with a .26 gap in 5th gear half way up the hill. I have since swapped to a smaller gap on copper plugs so that issue has been resolved.
This took place on a closed course with professional drivers only.
Used to have the same issue with IR's for top end runs, fine for 3/4 of the run then it'd stumble.
same cure.
(need a faster camera car)
