Mishimoto radiator?
Albert
May 13, 2009
1,710
Tempe, AZ
Its on here somewhere. I found that running poly or solid motor mounts, and a poly tranny mount prevented the engine to move and prevent the fan from hitting the radiator.
If you grab one, just grap a poly tranny mount and poly motor mounts.
I have solid mounts and my 2jzgte fan in my 1jz is like 1/4 away from my shroud, but doesnt hit because the motor doesnt move. I did break mine back when I had oem mounts that were old and torn
mkiii222
Troy, MI
They redesigned it a couple years ago. FWIW I have an original design on my 87 7MGTE that I've revved past 6k more than a few times and it still hasn't sprung a leak.
radiod
1,342
Abbotsford, BC
There still were some issues after the redesign IIRC. Bright side is if you do happen to have an issue they seem more than willing to work with you and warranty it.
