Milo's Booster Seat...
buckshotglass
I love all your sounds.
Big- I gotta get the car out in order to melt sand, so no way right now.
No cam news:( I figure I have a few extra days, so, thanks to many threads about pristine engine bays, I have been inspired. Clean, minimal bling. That's the plan.
I'm cleaning up this mess.
got the ABS out of the way. no damage.
cut the hole.
I got most of what I plan to, out.
Also today, I got my rear kit from Andy. A day early. We like that.
If I can, I will spray some paint tomorrow.:naughty:
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
HAHAHA....paint fumes!! My build thread has started an engine bay painting epidemic, and a laquer thinner addiction. It will be worth it man when you get all that new stuff in there, and it doesn't still look 20 years old in the bay!
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
This build is nothing short of amazing.. i hope to see your car at the next philly supra meet... hopefully i'll have something put together by then since my build hit a brick wall. Spring time should bring good things though.... hope i can pick up a good job in automotive come march when i graduate UTI
buckshotglass
Tookwik- Yep you started it. Now I probably will end up painting the whole car. :naughty: Thanks for that.
xarewhyayen- Glad you checked in. When is that next Philly Supras meet, I'll try to make it. That, right now depends on Brian Crower making the cams he should be shipping on Monday. Don't get me started.
So, I did spray today. I could get a lot better if I used these products more that once or twice a year, but it came out ok. My barn is the opposite of a paint booth, clearcoat and dust don't mix. Anyway, im happy it's done.
the bay, after color, before the clear.
the tape job
and since this paint is so expensive and I suck at estimating amounts, I prepped some other stuff so as not to waste any paint.
anyway, here it is cleared,
nicees color I ever sprayed, I think so. Black Ruby Pearl FTW
and I did have enough for the hood. those stickers were a PITA!
later:icon_bigg
buckshotglass
Jaguar_5 said:
Wow!! Very hot!!
I might have to paint my car that color... hmmm
If you want to win ROTY, you better find some Black Gay Blue Pearl, but I don't know if it exists yet.
I am loving this color, can't wait to see in the outside light.
it only shows the red under direct light, otherwise it looks black.
It's baking at 85 degrees overnight.
Truly waiting on cams...
empera
Authorized Vendor
Philly.
buckshotglass said:
When is the next Philly Supras event?? Am I worthy? I need thet logo, and want for more info?? Website? Cheesesteak? :icon_bigg Lemme know.
Im shooting towards May...memorial day weekend, hopefully everyone will be ready by then. we should drive down to Pat's and get some steaks but wouldnt have any place to park...maybe tony lukes :) Damn you just gave me an idea. as for the website, im too lazy to work on one and get domain and such. copy the url for the logo onto ur sig, if u wish.
buckshotglass
May should be doable. I may go to Don's in Boothwyn for a steak tomorrow, I gotta call my Uncle and see if he's around. I need one or two. I may have a plan for the PhillaSupras logo. I need to enlarge it a little first. Thanks.
buckshotglass
Specs on my DTA Fast Pro 8 standalone, no prob. BTW, you can't outrun dis pimpin', yo.
Here's what the DTA site has for specs. Thanks.
P8 PRO ECU Features
Without doubt the worlds most user friendly mapping software - FREE!
Eight individually controllable coil drivers for unequal firing or different cylinder advance.
Eight injector drivers, with individual adjustments, for sequential injection up to eight cylinders or control of up to 16 staged twin injectors.
Amplified Coils Support NEW
Full 3 or 4 wheel traction control with switchable, on dash, on/off and wet/dry settings.
Launch control with numerous options.
Turn off closed loop above TPS & RPM NEW
Full turbo anti lag facilities, switchable on dash.
Logging switch able on dash NEW
Voltage in warning limits during Mapping NEW
Manifold Pressure as main load NEW
Improved idle speed control NEW
Nine auxiliary outputs for various functions.
Improved, more flexible data logging capabilities NEW
Compensation for air temp / water temp / MAP or barometric pressure on fuel and ignition.
Closed loop Lambda control.
Full turbo pressure control variable by RPM with overboost protection.
Steering wheel button controlled start line RPM limit.
Full power shift cut.
Temperature dependant idle speed control via PWM valve.
Dedicated shift light output.
Serial output of data for dashboard NEW
Dedicated Tacho output.
Two stage main RPM limiter.
Dedicated fuel pump control.
Full start-up fuelling map.
Throttle transient enrichment map.
Self test facilities for ignition and injection.
Diagnostics and peak recording.
Real time mapping, no EPROM's required.
Selectable 20 X 14 lambda target map
In-vehicle fuel map building
Can use 5 volt linear lambda sensor with external electronics
Software programmable for most crank wheels, (Honda Blackbird, Rover, 36 - 1, 60-2 etc).
All main 3D maps (20 x 14) have user programmable break points.
ax. RPM up to 16,000.
Flexible PWM outputs linked to any input useable for any of the following;
Water injection (multistage)
Speed related power reduction (Drag bikes)
NOS control with fuel enrichment and ignition retard (multistage)
Fuel Mixture control for endurance racing
Twin Fuel pump control
Anything else requiring mixture and ignition control
linked to an input and an output.
