MHG question
kotu100
1,899
Easton, Ma
I have a used Cometic MHG, and a new HKS MHG.
the HKS is a 1.2mm and with my machined head and block this is insufficent.
my cometic, i cant remember exactly what size it is but i did the math to get the correct size when i did the rebuild the 1st time.
my question is, instead of cleaning all the viton off the old cometic and spraying with copper spray, could i remove all rivets and mix and match using the HKS outer layers and the cometic shim?
it is NOT stopper HKS gasket, and both have 3 layers.
kotu100
1,899
Easton, Ma
i've tried everything to get this viton off and it wont budge, i cant really spend 10 hrs trying to clean this thing...
i used acetone, paint stripper, brakleen, gasoline, surface prep, spray gun cleaner. none of it even softened it up.
i really only wanna do this once, so i'll try a few more things, any suggestions?
I would try soaking it in acetone for a while and then come back and try to scrub it off. Its not going to come off easy and there are many threads about this. Its not a quick or easy job.
paradox616
472
Melbourne, Australia
gaboonviper85;1564935 said:
Cause cometics are cheap...
Your call...I'm lazy and don't have an issue spending money if it's convient:-/
+1, i ended up just buying a new cometic the correct thickness.
have you inspected the gasket carefully to make sure its even reusable? IJ. had a few posts on cleaning a MLS head gasket maybe search for them.
Have you Tried brake cleaner?
kotu100
1,899
Easton, Ma
i've read multiple threads about reusing MHG, including Ian's.
nothing suggested is working to help in taking the viton off. and like Ian i dont want to use an abrasive on it.
i really dont see what the big problem is with swapping out shims.
all it is, is a different thickness sheetmetal.
the mating surfaces of the gasket are still good, the HG doesnt even have 5k miles on it.
i would just use the 1.2mm HKS but its too thin.
The thing i see wrong with swapping shims is there made by different companies and might have some differences. If you want to experiment go for it.
gaboonviper85
3,236
Northeast Philly
Why are you asking us for our "blessing" when you already have your mind made up?
You do what you want but so far everyone recomends you get a new gasket.
Your car....your motor....your choice!
kotu100
1,899
Easton, Ma
im not asking for your blessing, i just simply wanted more opinions, or to see if anyone had done this before.
and 3 members is by no means "everyone"
if no one tried new things, and did what everyone else said, where would we be today?
Ian thanks for the tip, ill measure everything and not just check it by eye.
kotu100
1,899
Easton, Ma
Ya that's true, I didn't take em apart till this morning tho.
The shim has the stock bore, the hks hg was oversized.
