Master Cylinder Brace
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
R&D is done it works. But rember i have custom made soild upper shock mounts with short bolts on them so it dose not look like there is much grabbing in the threads but i know with the stock ones the bolts are much longer and will work with no problme. Here are the pics.
csnow
Matthew 6:33
Palm Bay, FL
Can you make a spacer that is the same diameter as the brace bracket. That way the strut bar will be even from strut tower to strut tower. Not sure if one side being a 1/4" inch higher on one side even matters.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
I was gonna order a diffrent size stock so the pound plate and brace are the same thinckness so when i dress up the welds it all will be even. Is that what you were talking about? Or do you mean for the passengers side?
Mr. Sinister
192
Chicago
He means one side will have the brace under the STB and the other side won't, meaning we'd need a spacer for the other side to keep both ends of the STB raised up the same amount.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
wesbeech;878703 said:
What worrys you with the bolts?
CSNOW i think the cheapest i could do if we got enough tpeople is $60.00 shiped with everything needed and a lifetime warranty if you some how break it send it back and ill fix it for free. But only if we can get enough people toghter.
the fact that the bolts do not fully thread.
But i'd be in for one considering no one else brought this up.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Like i said i have custom made upper shock mounts with bolts that are much shorter thean the factory bolts.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Well i instaled the today on my buddys car and tested it out here is a video of him pumping the brakes as hard as he can and there is no movement or flex with the brace.
Here is a video with it out the brace you can watch the mc move on my car it flexes much more than his but you can see the movement
http://www.youtube.com/watch?v=E7Z3dpAmf2I
And here is a video with the brace instaled as you can see the mc dose not move and he said tword the end of pedal travle it got much stiffer.
http://www.youtube.com/watch?v=l9OYdGvohXs
wesbeech
Feb 26, 2006
1,022
Akron Ohio
ValgeKotkas;882713 said:
So the installing of the brace results in exactly what then? Better braking or just better feel of the pedal?
Both actuly because the fire wall is no longer flexing instead of moving the fire wall you moving more brake fluid trough the system.
Tekdeus
Right now it is mild steel it could be don in aluminum but the price would significantly go up.
Today im gonna make the fixture and make 2 braces on it test them to make sure there right then im gonna try to get everything toghter to see about a group buy.
wesbeech
Feb 26, 2006
1,022
Akron Ohio
I know some of you were worried about bolt lengh and things along those lines well here is a pic of the brace on my buddies stock supra as you can see there is plenty of thread sticking up the nut so there will be no problmes there. And the bracre is compatible with TEMS for those of you who still run it.
