making more power with out going inside the 7m...?
GTsupra
20
perth australia
hey guys,
i have a ma70 with the 7mgte. i've recently ran out of mods to make more power from the 7m.( want bolt on mods only, don't want to go inside the motor) so i'm asking for some pointers.
my bolt on mods so far.
INTAKE + TURBO
air filter
exhaust
t70 turbo + exturnal w/gate + custom manifold.
boost controller on 20psi
ported heads + 3mm hks head gasket
light weight f/wheel
michrotec ltx12 stand alone ecu
independant coils
FUEL
sard fuel p/reg
550cc injectors
walbro f/pump
on 20psi i'm makeing 360rwp. 12.72sec 1/4 @ 116mph on mt semi slick
i want to get 450rwhp without going insde the motor... what can i do from here...:icon_conf :icon_conf :icon_conf need help
GTsupra
20
perth australia
well, the turbo is rated up to 700hp. i've had it on for 6 months now with out any problems, and thats running on 20 psi all the time.
the exhaust housing is .84on hot .70 cold.
if i go to a bigger turbo, what should i use...? t88....? hkst04z( same size as
t70)
C
cnewingham
Guest
I did 307rwhp at 13psi on stock turbo and fuel so something is wrong
westonboege
134
providence RI
+3mm headgasket is pretty thick isnt it? Did you have to take alot off of the head or something? His compression could be lower... Get an afpr and tune the hell out of it... you got a wideband?
Jspec7m88
1,583
Nappy City
I was going to say something about that 3mm HG earlier when I first read the thread...but I was assuming the head's been grinded down a little.;)...I hope so, anyways, otherwise, there could be a problem.:icon_conf
staticpat
Supra Chair!
Birmingham, AL
MK3Brent said:
With half of that boost, I made 315/320tq with a T-66 p-trim.
Yeah me too, with half of that boost I made 320rwhp with an upgraded ct-26
something's defintely wrong or you need a better tune.
GTsupra
20
perth australia
the head only got a light shave, not even .5mm.
i had ats turbo service to pull the turbo apart and it is quite big compared to the original ct26.
i got it on a dyno today to see what the afr is and it is running rich.
it made 339rwhp on 17psi and the afr is 10.5
and at 20psi its making 360rwhp.
i know it is running rich now, so what would i be expecting to get when it is tuned correctly ?
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
You can only do so much until you blow / spin something and are forced inside the engine :)
If you've only had a bit shaved off, why did you go with 3mm? Whats your compression?
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
I bet your compression is too low with that 3mm hg.
I made 368 at 18psi on a 60 trim ct26 and my a/f was 10.5.
