main studs help
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
wait what? you mean the nut and the bolt itself? or headstuds? wtf?
anyway im assuming youre talking about the way its in 2 pieces. bolt in 1st, then the top nut.
i165mk
93
FLushing Queens
ok i bought arp head studs and im installing them now when i install the headstuds i put them in how much pounds of tq do i do first and then how much wen putting the moly lube and then the nuts on can some 1 give me a walk thru on installing the arp headstuds and main studs plzplz
CPT Furious
Now MAJ FURY!
KDOV
Well, put the studs in til it hits bottom, put the caps on, then bolt them down per the TSRM pattern to the TSRM spec torque (for the headstuds, use more torque...how much depends on who you ask). The "stud" itself isn't really torqued when installling, the nut is...
Doward
4,245
Alachua, FL
Ok, first -
a "STUD" is a rod, threaded on both ends.
Head studs hold the head in place.
Main studs hold the crankshaft (well, the main caps) in place.
Please look up the difference.
quake
toyota tech
Apr 13, 2005
619
r.i.
did you remove the flux capasitor? lol
7MsuprO
322
Huntington Beach CA/Ohio
suprarich
Guest
Nov 9, 2005
2,187
ohio
PM me, I will walk you through any trouble you are having.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
It doesn't matter which you install first, main studs or head studs, they are holding down two completely different things and will not have any effect on each other if one is installed before the other....
