Ditto......CPT Furious said:Through the main caps on the bottom end. I think someone else should assemble your motor...seriously.
he should get a 1jz, that way he wont be able to blow it up no matter how hard he triesIJ. said:Put the wrench down and BACK away from the 7M!
did you remove the flux capasitor? lolCryoSlash said:wait what? you mean the nut and the bolt itself? or headstuds? wtf?
anyway im assuming youre talking about the way its in 2 pieces. bolt in 1st, then the top nut.
i165mk said:ok i bought arp head studs and im installing them now when i install the headstuds i put them in how much pounds of tq do i do first and then how much wen putting the moly lube and then the nuts on can some 1 give me a walk thru on installing the arp headstuds and main studs plzplz
mustangman05 said:is the motor even out of your car??
